Ekko Star
This is the modification process for the Sony range of players.
The process below is for the X800Mk2 RattleByte mod and is for educational purposes only. I would not advise attempting it and leave it to a professional. You can easily destroy your machine unless you have advanced skills.
You will need advanced soldering skills, steady hands, soldering iron. A digital microscope and hot airflow station will also be handy.
RattleByte Multi-region Board
Main board
Remove the main board from the machine. There are 8 points to connect to the multi-region board.
ZHR 6 pin 1.5mm pitch connector - this helps for a neat finish if you don't wish to solder to pins
Installed board
Once the multi-region board has been installed you will need to install custom modified firmware.
Your machine will then become fully multi-region and is able to play all region DVD's, Region A, B, C Blu rays and all region 4k UHD discs.
Thank you
Main board
Installed board
Thank you
