Sush40
Hi All
I'm looking to replace my TV and thinking of getting a 4K one. I don't need a high spec model as I'll only use it to watch regular TV (no sports) and occasional movies.
My budget is around 700. I'm looking for a 49'' preferably.
I've done a few research and I narrowed down to these models:
- SONY X800
- SONY X830
- SAMSUNG KU6400 (6470 preferably - with voice control)
- LG UH750 or 770V
I was going to get LG 668V which - on the paper - looked good (with extras like voice control and HK speakers) and it was reasonably priced at 500pounds for a 49''.
But I've seen it in the shop and I didnt like the design (quite bulky) and was disappointed by the picture quality to be honest.
I'm also interested in the LG UH 750 or 770V but again not too keen on the LG design and the picture quality wasn't mind-blowing (even though 770V is S-UHD and had Doly vision, 10Bits panel, etc).
So my questions are:
1/ Are LG 750 or 770V worth considering against the Sony's and the Samsung?
2/ Is it worth paying 50pounds extra for the SONY 830 compared to the 800 (I think the only difference is the 60Hz/120Hz - panels would be both IPS being the 49'models) Or are there any more differences between the 2
3/ Finally, which is better between X800 and KU6400?
So here are the pro's and con's I've found so far:
- Sony's processor is much slower and apparently menu can be sluggish
- screen is IPS (on the 49'' models) so the blacks are probably worse than on the Samsung TV
- there's no local dimming
- Also I'm not a fan of the remote control
+ On the other hand I really like the picture quality of Sony
+ Motion is better than on the Samsung's
SAMSUNG
- Judder! Is it really bad?
- SONY X800
- SONY X830
- LG UH750 or 770V
SAMSUNG
