Sony x3500 vs Sharp XL2E vs Panasonic TH-46PZ85E
badlydrawn69
Joined
Dec 27, 2007
Messages
4
Reaction score
Points
2
Hi all,
I am at the moment looking to buy a display and would like your support/opinion if thats alright. : )
The upgrade I am looking at are one of these models:
40" or 46":
LCD
Sony X3500 or X3000 if anyone can explain the difference.
Sony W4000
Sharp XL2E
Plasma
Panasonic TH-46PZ85E (think the E is for europe, don't know)
My usage would be approx. 40% SD sat (awful quality), 40% PS3 gaming and 20% BR movies.
Are those decent choices for this type of usage, or is there something coming right around the corner (1-2 months) that will blow them out of the water...
Your suggestions are much appreciated!
PS: First post, so greetings to all as well!
I would avoid the sharp common banding issues.So its between the others.The PZ85 is an excellent set but plasma which makes an lcd safer because as I see you intend to play much games.X3000 s the same technically just cosmetics.
Thanks for the input - thinking of getting either the 40/46 X3000 then. Just a quick one, is there a replacement for the x3000/x3500 models coming soon or is it still a way off?
Its still a long way..september time
TV Buying Guide - Which TV Is Best For You?
Back
