Sony Wega36" service menu help?
Discussion in 'General TV Discussions Forum' started by Gordon @ Convergent AV, Nov 2, 2001.
  1. Gordon @ Convergent AV
    Jul 13, 2000
    14,207
    +3,042
    As above. I have unit I wish to measure and do greyscale on. Anyone know how to get in to service menu?
    Gordon
  2. William
    William
    Sep 4, 2000
    60
    Shropshire
    Gordon
    I don't have the same TV to verify this, but found these details on an old post which claims to be the right method for this TV.
    1. Turn TV on with the remote control
    2. Turn TV off with the TV on/off switch
    3. Hold down the two dimpled buttons on top of TV, and keep them held down.
    4. Turn the TV from TV on/off switch.
    5. After a few seconds the set will come on. Release the two dimpled buttons.
    6. "Menu" on the remote now toggles between the standard menu, and the service menu.
    Hope this helps
    William
