Sony WEGA TV problem.. Standby flashing
Discussion in 'TVs' started by tomacwhite, Jan 7, 2004.
  1. tomacwhite
    tomacwhite
    Oct 21, 2003
    234
    Midlands, UK
    +21
    My parents got me up early this morning to ask why the TV isnt working. I thought it might of got confused with itself like it does with Sky sometimes, and knocked itself off of the right AV channel. However upon inspection I noticed the standby light flashing constantly. Looking in the menu, it says to contact the Sony Service Centre for repair. The TV is covered for damage/breakages anyway so it should be repaired or most likely replaced (its an early WEGA).
    I just wondered if anyone knows what this normally means? Is it one fault or could it be anything?
    For the record, you can get sound, and switch channel, but there is no tube action at all. No picture, no green AV channel labels or anything.. Tube dead?
    Thanks.
