sony wega 42"
Discussion in 'TVs' started by karlos130, Jan 3, 2005.
  1. karlos130
    karlos130
    Hi all just new here, after some advice!!
    Got a rear projection tv as above
    Only 3 months old but can see a noticable shadow line accross the centre of screen on certain programmes ie light ones
    Is this normal or should i be concerned????
    Thanks in advance
    :smashin:
  2. Capt Morgan
    Capt Morgan
    karlos,
    Not sure how much help you'll get here mate, this forum is dedicated to DLP RP sets and the Sony's a LCD.
    Perhaps you could get a mod to move this to the correct forum.
