Posted these in the main forum, but they got lost under other posts pretty quick.
After a long time of tinkering I ended up with these.
Everyone has different preference, but these could be perfect for some or a good starting point at least.
Tried to include the important details the best I could. You should end up with the same results if you follow them as I have laid out
''First thing to do. Turn Light Sensor and Shop Mode off!''
Built-in Satellite/USB playback/Internet video (These use the same preset)
Scene: Cinema
Taget Inputs: Common
Picture Mode: Cinema 1
Backlight: 6
Contrast: 95
Brightness: 52
Colour: 50
Hue: 0
Colour Temp: Warm 2
Sharpness: 50
Noise Reduction: Off
MPEG Noise Reduction: Off
Dot Noise Reduction: Off
Reality Creation: Manual
-Resolution: 10
-Noise Filtering: Min
Smooth Gradation: Off
Film Mode Auto
Advanced Settings
Black Corrector: Off
Adv. Contrast Enhancer: Off
Gamma: -2
Auto Light Limiter: Off
Clear White: Off
Live Colour: Off
White Balance:
R Gain: -3
G Gain: -5
B Gain: -0
R Bias: -0
G Bias: -0
B Bias: -0
Detail Enhancer: Off
Edge Enhancer: Off
Skin Naturaliser: Off
LED Motion Mode: Off
Playstation 4
(If scene select is set-up correctly, the console automatically switches between Cinema & Game modes once it recognises the material that it is playing, Eliminating the need to change manually every time)
IMPORTANT: For the following settings to look correct, Make sure the Dynamic Range setting of the TV AND THE PS4 is set to Full RGB. No good just setting it on the console. The TV needs to be set also. PS4 Video Output Setting should be.... Range=Full, YPb/Cb Pr/Cr Range=Full, Deep Colour=Auto.
PS4 Game Inserted/Operating System...
Scene: Auto (24p Sync)
Taget Inputs: Current
Picture Mode: Game-Standard
Backlight: 6
Contrast: 90
Brightness: 52
Colour: 58
Hue: 0
Colour Temp: Warm 1
Sharpness: 60
Noise Reduction: N/A - Off
MPEG Noise Reduction: N/A - Off
Dot Noise Reduction: N/A - Off
Reality Creation: Off
-Resolution: N/A - Off
-Noise Filtering: N/A - Off
Film Mode N/A - Off
Advanced Settings
Adv. Contrast Enhancer: Low (Low is more subtle, Medium is a bit too strong and artificial)
Gamma: -2
Clear White: Off
Live Colour: Low
White Balance: ALL ON DEFAULT 0
Edge Enhancer: Off
PS4 Blu-ray Inserted...
Backlight: 6
Contrast: 95
Brightness: 36
Colour: 50
Hue: 0
Colour Temp: Warm 2
Sharpness: 50
-Resolution: 10
Film Mode Auto
Advanced Settings
Gamma: -2
Clear White: Off
Live Colour: Off
White Balance:
R Gain: -3
G Gain: -5
B Gain: -0
R Bias: -0
G Bias: -0
B Bias: -0
Edge Enhancer: Off
PS4 DVD Inserted...
Picture Mode: Standard
Backlight: 6
Contrast: 95
Brightness: 36
Colour: 50
Hue: 0
Colour Temp: Warm 2
Sharpness: 50
-Resolution: 10
Film Mode Auto
Advanced Settings
Gamma: -2
Clear White: Off
Live Colour: Off
White Balance:
R Gain: -3
G Gain: -5
B Gain: -0
R Bias: -0
G Bias: -0
B Bias: -0
Edge Enhancer: Off
Sound Setting: Same For Everything
Target Inputs: Common
Sound Mode: Standard
Sound Effect: N/A
Auto Surround: On
Sound Booster: Off
Equalizer:
+5 +4 0 0 0 0 0
Voice Zoom: 0
Live Football Mode: Off
Advance Auto Volume: Off
Volume Offset: N/A
Balance: Centre
-----That's It-----
