hodg100
Outstanding Member
- Joined
- Aug 8, 2005
- Messages
- 14,220
- Reaction score
- 4,522
- Points
- 6,489
Disclaimer: The settings below are supplied for information purposes only. We make no guarantee that using the adjustments below will improve your TV's picture, they may even make it look worse. Every TV, even from the same manufacturer and model number will vary, as will the environment the TV is used in. For further information on how to set up your TV, please follow the steps in our Picture Perfect campaign.
To find a professional calibrator near you, see our Custom Installer and Calibrator Directory.
You can read the review here: Sony 50W29 Review
Scene Select: Cinema
Picture Mode: Cinema 1
Backlight: 3 (Make sure you turn the Light Sensor off in System Settings/Eco)
Contrast: 80
Brightness: 50
Colour: 50
Hue: 0
Colour Temperature: Warm 2
Sharpness: 50
Noise Reduction: Off
MPEG Noise Reduction: Off
Dot Noise Reduction: Off
Reality Creation: Manual
Video Area Detection: Off
Resolution: Low 0 - 20 (play with it depending on compression)
Smooth Gradation: Low
Motionflow: Off/True Cinema
Film Mode: Auto
Advanced Settings
Black Corrector: Off
Advanced Contrast Enhancer: Off
Gamma: -1
Auto Light Limiter: Off
Clear White: Off
Live Colour: Off
White Balance: Red Gain -3, Green Gain -8, Blue Gain 0, Red Bias 0, Green Bias 0, Blue Bias 0
Detail Enhancer: Off
Edge Enhancer: Off
Skin Naturaliser: Off
Contrast: 80
Brightness: 50
Colour: 50
Hue: 0
Sharpness: 50
Film Mode: Auto
Advanced Settings
Gamma: -1
Clear White: Off
Live Colour: Off
Edge Enhancer: Off
