Sony W705/W706 - Calibration Settings
Juancafr
I need a good setup for when I play Xbox One, PS3, Wii U and to watch movies, series and TDT to be possible but what interests me more is for consoles can you help me? thank you
Dibils
for TV/Movies i used this guys settings with a few changes of mine Sony 2014 W7 / W8 (1080p Edge LED TV) Owner's Thread | Page 31 | AVForums
my one(bold ones are my changes, nothing huge):
Turn the light sensor off first(VERY IMPORTANT):
Scene select cinema
Picture mode cinema 1 or 2
Backlight 8
Contrast Max
Brightness 51
Colour 50
Hue 0
Colour temp neutral
Sharpness 50
Nr off
MPEG nr off
Dot nr off
Reality creation manual resolution 15 noise filtering 6
Smooth graduation low
Film mode auto
Advanced settings
Black corrector off
Adv contrast enhancer low
Gamma -1
Auto light limiter off
Clear white off
Live colour medium
White balance r gain 0 g gain -2 b gain 0 r bias 0 g bias 0 b bias 0
Detail enhancer Low
Edge enhancer off
Skin naturaliser off
i will post my gaming settings below this
Dibils
Ok for gaming(X1), this may not be to everyones taste, i like a colourful bright picture but try to avoid black or white crush. first make sure your black level settings are right. put the X1 Color Space to "TV" then change your TVs accordingly, by default its on Auto but i dont trust it lol so i put mine to Limited, to access: (Home -> Scroll to settings above -> Display -> Video Input Settings -> Dynamic Range -> change to Limited for the specific HDMI port)
Scene select Game (important for the input lag but also, more importantly, for the full 4:4:4 reproduction)
Picture mode Game-Original
Backlight 9
Contrast Max
Brightness 49
Colour 60
Hue 0
Colour temp Neutral
Sharpness 50 (Alternate: 40 with Detail enhancer on Low)
Nr off
MPEG nr off
Dot nr off
Reality creation OFF (this is important, messes up the text otherwise)
Smooth graduation OFF
Film mode auto
Advanced settings
Black corrector off
Adv contrast enhancer off
Gamma 0
Clear white off
Live colour High
White balance r gain 0 g gain 0 b gain 0 r bias 0 g bias 0 b bias 0
Detail enhancer off
Edge enhancer off
i also have a bit more muted and darker version of this on Game - Standard but i havent used it enough to gather whether its good. main change is Gamma set to -2 and color set to 50-55
Brunadas
Hi guys,
Recently bought a 42w705b as well and I've been trying to mess with the settings for gaming but it isn't 100% according to me.I'll try this settings tomorrow and then I'll say something ;) Thanks in Advance.
Brunadas
Thanks for the settings,used for Gaming and only changed backlight to 8 and gamma to -1 and they are perfect ;)
Brunadas
yep put mine to gamma -1 too recently. glad you liked it
Yeah man thanks ;) I still got to see better IF the Live Colour adds input lag or not,didn't have too much time to see that.And gotta see the Cinema Settings as well.
Edit: Just tried and I use Live Colour on low,no lag ;)
Dibils
i wonder if it adds lag if you have it set high rather then low. i would guess not but i am gonna test it on FIFA 14 i think
one change i also made is made the tint 3 towards green. there was abit too much red on skin tones, not sure how it is on yours though
Thank you very much Do you have a PS3?
not anymore, but i would think the settings would be similar. just have to make sure your colour space is set right
Brunadas
Allright so when u test then say something if u can ;)
I have R Gain -1 and B Gain -2.All the rest is 0.How is yours?
Dibils
FIFA 15 looks amazing for me using the above settings, as does Destiny and any other game.. miles better then the LG TV i had
aslong as you have your color space and TV Dynamic range to what i said above.. everything else is personal preference tbh. there is no 'one fits all' calibration setting. for example i keep going back and forth with brightness, backlight and gamma since i might prefer a different look for a certain game. right now i use this:
Backlight Max
Contrast Max
Brightness 50
Colour 60
Hue G1
Colour temp Neutral
Sharpness 50
Nr off
MPEG nr off
Dot nr off
Film mode auto
Advanced settings
Black corrector off
Gamma 0
Clear white off
Live colour High
Detail enhancer off
Edge enhancer off
ItalianGuy
Do you guys have any settings for watching football on the tv!?!? When i presso the football mode button everything is too bright and saturated...it's not good? I would prefer tweaking myself the sport mode...any ideas?
Juancafr
i am guessing you wanna say something is wrong with color.. again change it to your preference! main settings is contrast and brightness, the rest is however you like it
Color 60 and High is very exaggerated is what I think
Similar threads
Podcast: Sony XH95 TV, Klipsch The Fives Speakers & Bias Light Reviews + Best of the Month
Trending threads
Latest News
Cambridge Audio unveils new-look SX speaker series
  • By Andy Bassett
  • Published
Google unveils Pixel 5 and 4a 5G smartphones
  • By Andy Bassett
  • Published
Google launches new Chromecast with Google TV
  • By Andy Bassett
  • Published
AVForums Podcast: 30th September 2020
  • By Phil Hinton
  • Published
Sony Android TVs add Now TV app in UK
  • By Andy Bassett
  • Published
