Sony W4500 and PC DVI Connection
Discussion in 'Sony TVs Forum' started by sun4u_m, Feb 6, 2009.
  1. sun4u_m
    sun4u_m
    Feb 3, 2009
    9
    Hello
    I want to connect my PC with new Sony W4500 series TV.
    PC has DVI out and Stero Jack (3.5mm).
    I have DVI to HDMI cable, which works fine and transmitting great video.
    Issue is sound, I have cable 3.5mm headset to Phono (RCA) Cable.
    How do I get sound on TV:
    If I change input to HDMI, then there is no audio and if I change it to AV3 (which has phono in), there is no video?
    Please suggest...
    Thanks in advance..
  2. RottenFox
    RottenFox
    Mar 11, 2006
    17,179
    +56°28' 10.92"/-2°59' 21.48"
    +4,289
    you need to read your manual..:smashin: , and look at the back of the tv.
    the audio lead,you need to use is a 3.5mm - 3.5mm lead.
    which will go from your pc, to the 3.5mm port right next to the hdmi 2 socket.
    so connect the dvi-hdmi lead from your pc, to hdmi 2,and the audio cable, to the 3.5mm port, right next to it.
    you will see a similar socket setup to the right of it,for vga/audio input,which also uses a 3.5mm port.
    also, it may be that you get a slightly better picture from your pc using vga-vga, than dvi-hdmi, but thats for you to try.
