D
darren7
Im a bit lost,
Ok guys all my bits are here and I am ready to mount the projector, thought I wouldjust plug it in and point it at the wall just to see.
I have gone through the book a few times and it still seems quite muddy to me.
One of you guys said put it on a stall to se how far back you need to mount it, (Unicol), well what do I test it with, I cant see it in the book, I have put a disk in the player and connected it up but it is quite blurry, so I disconnected this and just used the projector, there is a test pattern do I use this? If so should it fill the screen exactly or just under or what?
I cant read any of the menus that come up on the pj when I hit the menu button; they are all too blurry to see.
So as you can see I am a bit stuck, please nice people with the VW11HT could you just run me through your install from the start, I am at a loss with the distance thing as I cant get it to focus, am I panicking? YES.
How do I set this thing up from the start?
All help appreciated
Darren
Darren
