sony vw11 Component lead lengh
Discussion in 'Projectors, Screens & Video Processors' started by darren7, Aug 15, 2002.
  1. darren7
    darren7
    SONY VW11HT
    I have just got the this projector and would like some advise on the Component input.
    Now some poeple need to have the dvd player some way apart and I would like to ask a few questions.
    What is the distance that some of you are running on the cable side.(Component )
    also I would like good quality cables for this but most seem to be 1 metre or maybe 2, I think I will need quite a bit more than this.
    can you good people tell me your Component cable setups and the sort of price I should pay and where from.
    D
  2. Pip_UK
    Pip_UK
    Darren,
    My component leads are 10m
    Custom made from http://www.keene.co.uk
    They are thick cables but give a fantastic picture
    Think it cost me around £90
    Pip
  3. nigel_williams
    nigel_williams
    Jan 5, 2002
    447
    South London
    +3
    Mine are 10m Van Damme available from the Media Factory for ~ £42. They are 75ohm OFC and used by most professionals.
  4. darren7
    darren7
    Thanks guys very much.
    Darren
