Sony VW10 setup
Discussion in 'Projectors, Screens & Video Processors' started by slingshot, Nov 22, 2001.
  1. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    This isn't a big problem but ...
    Last night I borrowed a copy of T2 and ran through the THX setup stuff on the disk (I've already previosuly set it up using VE).
    Anyway theirs 1 test that has a circle surrounded by 2 line rectangles at the edge of the screen. The left hand line of the outermost rectangle doesn't get displayed. I switched to component inputs from S-Video and again it's not displayed but you can change the H&V on component inputs.
    Can anyone explain this ? And if it's possible to get the line displayed on S-Video inputs ?
    DVD player is A Tosh SD9000.
    Slingshot
  2. graham.myers
    graham.myers
    I'll reach for my T2 disk and see what happens on mine
  3. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,529
    Somewhere in South Yorkshire
    +6,000
    You will need to adjust the h-position and/or h-size values for you s-video input. You will need to be in the service or factory menus to get access to these settings.
    see
    http://www.munsil.com/VW10HTFaq.htm
    for details
  4. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Cheers, I've already got the service menu codes, I didn't notice anything on their, but I'll have another look tonight.
