Sony VW10 Aquired
Discussion in 'Projectors, Screens & Video Processors' started by rossobonks, Jun 12, 2002.
  1. rossobonks
    rossobonks
    Ive just aquired a Sony VW-10 for absolutly nothing! Just 1 problem - no lamp unit! The filters on the machine are also clogged with tobacco smoke and more than likely is the optical engine but thats no problem.
    Before I go and order a new lamp off Sony I need to check that the LCD optical engine is in perfect working order etc so...
    Does anyone know what wattage the lamp unit is and does anybody have an old lamp I could use the actual lamp basket because I have a 120w UHP lamp from a Sony VPL-x600 machine for which I have a feeling that the VW-10 uses the same actual lamp reflector has the VPL-x600.
    Any info greatly appeciated.
    Many Thanks
