Sony vw10,11,12ht "aspect" modes
Discussion in 'Projectors, Screens & Video Processors' started by coolhand101, Dec 27, 2002.
  1. coolhand101
    coolhand101
    I was doing a search for the sony vwht series to try and see pictures of the screen modes it has, ie a on a 16x9 screen with its wide, zoom, normal, and thru modes.
    i havent had any luck with photos on its different aspect settings on the net only other details concerning the perfect setup, better blacks and user/service menus.
    if anyone knows of any info on the subject -thanks
    what i really need to know is on a 16x9 screen and viewing a 2.35:1 film would its "thru 4x3 and 16x9" modes be the same height for a 2.35:1 film.
    thanks again
  2. PhilGrover
    PhilGrover
    May 20, 2003
    32
    Loughborough
    You have found the answer by now - I have only just come across your post.
    I have a 10HT and the thru modes basically turn off the scaler. 4:3 and 16:9 thru modes are the same height, but differing widths, the same as the normal 4:3 and 16:9 modes are, but only taking up a small section in the middle of the panel.
    Phil
