Sony VTXD800U Problems after powercut
Discussion in 'Satellite TV, Sky TV & FreeSat' started by surfermc, Jan 30, 2005.
  1. surfermc
    surfermc
    Dec 11, 2004
    90
    +11
    The Sony VTXD800U has been fantastic until a powercut on Wednesday, since then I have to pull the mains lead out of the wall socket, plug it back in again, to get it to work properly. This is the only way that I can get it to switch the TV to the AV input, otherwise it tries to switch but does not display a picture.
    Any suggestions would be appreciated.
  2. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    Have you been into the setup?? There area few options for SCART switching on the Sony ;)
  3. surfermc
    surfermc
    Dec 11, 2004
    90
    +11
    I've tried the settings within the menu. I've tried different scart leads. The Sony box will only switch the TV to AV once after the mains plug has been pulled. :(
  4. jaymac
    jaymac
    Jan 15, 2003
    1,725
    63
    North Somerset
    +138
    Have you checked the wee Tv/Dtt swich
  5. surfermc
    surfermc
    Dec 11, 2004
    90
    +11
    Yes tried that.
    I was wondering if there was anyway hard reset for the box?
  6. JohnW14
    JohnW14
    Aug 6, 2004
    77
    Wiltshire
    Press and hold the button on the front of the box until the LEDs flash. This has always cleared up any problems I've come across.
  7. surfermc
    surfermc
    Dec 11, 2004
    90
    +11
    Thanks that almost works. If I press the power button until the LED goes orange the box then switches the TV to AV but only once. Atleast I don't have to keep pulling the plug. :)
  8. DRGL
    DRGL
    Mar 30, 2004
    746
    Shropshire,UK
    What TV is this connecting to?? Maybe a setting in the TV has been lost too?? Pin 8 on the SCART plug contain the AV switching/widescreen switching voltage.
  9. surfermc
    surfermc
    Dec 11, 2004
    90
    +11
    The TV can still be switched by the DVD player using the same AV socket and scart cable.
