Sony Vtx-s760u / S750u
Discussion in 'Satellite TV, Sky TV & FreeSat' started by milgo, Jan 29, 2003.
  1. milgo
    milgo
    I have been thinking of purchasing one of these sony digi boxes 2nd hand on ebay, It would look better in the stack beneath my DAVS880.
    Will it perform better that my SKY supplied Grundig?
    Are there any major differences between the 2 models?.
    Will I simply be able to remove my existing STB and replace it with the sony, or do I have to inform SKY?
    Thanks.
  2. Rookies
    Rookies
    Jan 4, 2003
    4,900
    103
    +345
    I can only answer 1 question.
    You will have to inform sky, it simple as i have done it before, what they need to do is reg your viewing card to the new sky box. What they ask you to do is to go into services, system setup then to system details and you just read out what it says on there to the tech guy at sky ta da they get you sorted
  3. Fernsehman
    Fernsehman
    Electronic equipment requires a minimum 100mm air gap above if you expect reasonable reliability.
    Probably not. The Sony is allegedly renowned for nice looking box but mediocre pictures.
    Dunno but the early model came with the optical output disabled. There was a hoo hah about enabling them but I don't know if they all were. This might not matter to you of course. It won't give 5.1 Dolby anyway.
    As the man tried to write, you phone SKY with your on-screen serial number and version number and ask them to authorise your old viewing card in the new box.
    Fman
  4. Flimber
    Flimber
    Sep 22, 2002
    13,364
    Yorkshire
    +4,477
    My mint 760 will be for sale imminently at below eBay prices. I'll probably post an ad in the classifieds.
    Mike.
  5. Marcus Wood
    Marcus Wood
    Dec 28, 2002
    376
    London
    +4
    I have a 750 and it came with the optical output working. But there was a slip in the box saying that the optical output had been disabled.
    Apparently, the Sonys don't have the neccessary hardware to output DD, though.
