Sony vtx-s750u problems using rf out-1 and rf out-2
Discussion in 'Satellite TV, Sky TV & FreeSat' started by Esky, Apr 19, 2005.
  1. Esky
    Esky
    I have just been given a sony vtx-s750u sky digibox and have got it up and running to a point. I can view all the channels on my main tv via the scart lead, but am unable to tune a second tv into the RF out-2. I've also tried using the rf out-1 with the same result : the picture is really weak / heavy snow.
    I've tried 2 tv's and both have the same weak picture - any ideas ?!?
    TIA
    Esky.
  2. Esky
    Esky
    I forgot to mention that I can tune into the terrestial channels, just not the satellite signal.
    Esky.
  3. Bluevanman
    Bluevanman
    Try changing the RF output. Go to services, press 0,1,select,4.then input the channel number that you want. You can use anything from 21 to 69. You need to be at least 3 away from any terrestrial channels and from your vcr modulator output. Most vcrs tune from 21 to 36. You can get a list of the channels for your local transmitter from here http://www.wolfbane.com/uktv.htm
    All you need to do then is save the new settings in the menu and tune in your TV's.
  4. Esky
    Esky
    Mmmm ... There doesn't seem to be an option 0 from services ! All I have is :
    1 Using your sky digibox
    2 Telephone numbers
    3 Parental control
    4 System Setup
    5 Favourite channels
    6 Other channels
    I've tried pressing 0, pressing and holding 0 ... to no avail.
    Esky
  5. big@l
    big@l
    Should of been 4, 0, 1. Looks like he had a typo.
  6. Esky
    Esky
    From Services - option 4 (system setup) I get the following options :
    1 Picture settings
    2 Sound settings
    3 Language & subtitles
    4 Add channels
    5 System details
    6 Signal test
    7 System test
    Still no option 0 !
  7. big@l
    big@l
    Although the option is not listed, just press 0, 1, select and a new menu will appear.
  8. Bluevanman
    Bluevanman
    Ooops.Yeah, sorry Esky I missed out the first 4. The correct sequence is services,4,0,1,select,4,then put in the channel number then go down to save new settings and press select,then backup until you get back to where you started. As big@al says, when you press the 0 nothing happens on screen, it just gives you access to the hidden installer menu.
  9. Esky
    Esky
    Hey guys,
    I've tried pressing 0, pressing and holding 0, (I've even tried 8 and 9) but there isn't any hidden menu appearing !
    Grrrrrr !
  10. big@l
    big@l
    When you press 0 you will not see anything until you press 1 and select. Pressing 0 just tells the box to branch to a hidden menu.
  11. Esky
    Esky
    Doh !
    Got it sorted now ... thank you both for your help.
    Cheers,
    Esky.
