Sony VTX D800U Sound but no picture!
Discussion in 'Freeview & YouView' started by oxfordblue, Sep 21, 2007.
  1. oxfordblue
    oxfordblue
    I have previously set up the above box and had it working fine, although with a problem with ghosting. I tried (unsuccessfully) to rectify that and not being an expert contrived to adjust the wrong pin on the scart cable etc!
    However, I have now purchased a new scart cable and set the system up as before but now have only sound and no picture. I have tried adjusting the scart connection but this has not helped!
    Any advice would be much appreciated!
  2. ianjm
    ianjm
    May 28, 2006
    96
    +8
    Another busted SCART cable seems like the most obvious explanation!
    You could sneakily buy another one from Argos to test, then return it under their 16-day no-questions-asked return scheme?
    A second possibility might be much worse, did your pin fiddling damage the SCART connector on the box itself?
  3. Jimmo 32
    Jimmo 32
    Apr 22, 2007
    211
    +24
    Make sure the scart is pushed firmly home,if it is not it can give the symptons you describe.
