Sony VTX-D800U Scart Connections
Discussion in 'Satellite TV, Sky TV & FreeSat' started by junya, Aug 16, 2005.
  1. junya
    junya
    Hello,
    A quick query before I purchase one of these. My TV has two scarts, only one of them being RGB. I basicly want to connect my DVD player and this STB to the TV, both via RGB.
    So is it possible for me to connect my DVD player to the scart 2 on this STB and the STB to scart 1 on the TV, and have both RGB? Or is the scart 2 on the STB not an RGB one?
    Thank you.
  2. Media_Man
    Media_Man
    I think what you are asking is does the second (VCR) scart have RGB 'pass through'...and i'm almost certain it does.
    This is because i have the Sony D800 myself - and i plug an imported US Game Cube into it with a special RGB cable. This would not work if the input wasn't RGB capable as my TV does not support NTSC on that particular input.
    Hope that makes sense. :)
  3. junya
    junya
    That's great then. Thanks for the reply Media_Man.
