K
Kimba
Okay, you can colour me confused.
I'm currently using a Sony VPL-X600 (XGA, 650 ANSI lumens, LCD) projector in my home cinema system. I recently acquired a Sony VPL-CX11 (XGA, 1500 ANSI lumens, LCD) which was in need of a new lamp.
Since the VPL-CX11's lamp was past it's replacement time, I didn't think it was unusual to see a dimmer image in comparison to my older 650 lumen projector. When I replaced the lamp however, I found little or no improvement. It's still significantly less bright than my old Sony.
I can only think of two scenarios here;
(1) I haven't reset the lamp counter (while I know how to get to the factory and service menus in Sony projectors, I can't find how to do this - any tips?). Is there some clever Sony function which dims the lamp a little when it's past it's rated life? If this is the case, resetting the projector should fix it.
(2) I've got a frooged projector. I've heard that TFT panels tend to die reasonably quickly. Given that this unit was manufactured in 2001 and doesn't appear to have been too badly thrashed (especially in comparison to my much older X600), this seems a rather short lifespan.
Any advice or suggestions would be greatly appreciated!
- Kimba
- Kimba
