Sony VPL-X1000 Projector Lamp/Cover Light stays on
B
bob2005_wow
I need some help, Does anyone know what it means when the used Projector I purchased on EBAY, the lamp is not turning on, I get the on Green light come up then within a few seconds, The Lamp/Cover light comes on and no lamp.
I only had this projector delivered this afternoon and I sure would like some help to see the lamp come on.
If anyone out there has the same type of projector, help would be very appreciated.
Bob
matblack
http://www.docs.sony.com/release/VPLPX20.PDF
Check out the description of the lamp/cover light on page 11 of this manual, its for another unit but I am sure the function is the same.
It looks like the bulb is dead but may just be that the cover over the lens and/ or air filter is not on securely
See my response on your other thread too
MB
B
bob2005_wow
I just had to fork out another $665 for a replacement lamp, and I am waiting for it to arrive tomorrow,,,
Thanks again
Bob
Panasonic HZ2000 OLED TV Review: The best OLED for movie viewing in 2020
