sony vpl w400
Discussion in 'Projectors, Screens & Video Processors' started by krusty, Nov 7, 2004.
  1. krusty
    krusty
    i have the above projector, and seem to have a problem. i bought this from a friend and ive only used it 4 times as its not fixed to a ceiling and i have 2 drag out the ironing board 2 set it up. today i went to use it and for some strange reason its all out of focus ,and i can not seem to alter the focus by any means. i can turn the large part of the lense to alter the size but thats about it . i know in the past ive managed the focus...but i cant do it now. also the projector seems to take a while 2 fire up and the lamp light tends to give a warning flash!also how do i tell how many hours have been used on this projector. help :lease:
  2. Oakleyspatz
    Oakleyspatz
    Oct 9, 2004
    3,576
    Woking
    +231
  3. krusty
    krusty
    i have had a another look and its the focus ring that will not move, has this anything 2 do with the fact the bulb has finished its lifespan
  4. RTFM
    RTFM
    Mar 6, 2003
    1,014
    38
    Horsham, West Sussex
    +17
    The focus ring will not have anything to do with lamp life.
    You may have to be a bit firm with it if it is stuck at one end of its travel.
    Jeff :rtfm:
