RockMonster
Hi All,
In a bit of a HD quandry, is it worth the few extra squids to purchase the VW80 over the VW60??? I'm on a bit of a budget, have extra costs as well thought, HDMI 5/2 switch (On that is the Octava 5/2 switch any good), cables, dedicated Bluray player. If I can afford it might go down the 5000ES route... as most of my existing kit is ES standard and I love the build quality and additional features not to metion the display detail.... open to all advice, especially if your an owner of any of the components mentioned, comments would be gratefully appreciated.
Currently own
All Sony, DVP-999NS, STR-DA9000ES, VPL-HS10, PS3-80Gb
Regards,
R
Currently own
Regards,
R
