Sony VPL-VW10HT
Discussion in 'Projectors, Screens & Video Processors' started by Dangerous, Oct 3, 2001.
  1. Dangerous
    Dangerous
    Here,s one for the tech,s amongst you. I have connected my Ntl digital box via RGB(boosted and synched) to input B which is set to recieve DTVGBR. I either have no picture, a distorted picture or a message saying frequency out of range. Suggestions very much welcome.
    Regards
    Dave
  2. Dangerous
    Dangerous
    I have found the answer to my question. I originally purchased a scart to RGB with composite sync however the manual say sync on green which means that pin 8 and pin 11 need connecting on the scart but for some strange reason I still have to connect the composite sync lead. But it works which is the main thing.Hope this helps anyone who may encounter a similar problem.
