Sony VPL-VW10HT
Discussion in 'Projectors, Screens & Video Processors' started by Dangerous, Oct 3, 2001.
  1. Dangerous
    Dangerous
    I am in the process of fixing my projector to the ceiling can anyone tell me if it is important to locate the lens exactly in the middle of minimum and maximum travel distance from the screen, it is currently about 110mm further away. :cool:
  2. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    I assume you've taken the calculations from the manual ?
    In which case the minimum and maximum are the min and max at which you can the use zoom on the lens to fill the screen.
    So as long as your distance is between these 2 figures then it's not a problem. I mounted mine slightly further back than the midpoint just to make fitting slightly easier.
    If you think you may be getting a different size screen at anytime, you may want to try and take that into account in the positioning so you could simply alter the zoom for a new screen.
    Hope this makes sense and helps.
    Slingshot
  3. gwbailey
    gwbailey
    Hi Slingshot, In the sony brochure it says that for a, 16:9 100 (inches) Screen (a) Min-3270mm, Max-3780mm. so you reckon it should be about 3570mm from the Screen?
    Also, when they say screen size 16:9 100 (inches) are they saying 100 inches Width or 100 inches diagonal?
    Cheers,
  4. Dangerous
    Dangerous
    Thanks for the reply slingshot. I am now up and running and the picture seems ok. I will be posting again shortly as I have a input signal problem, maybe you will be able to help.
    Regards
    Dave
  5. slingshot
    slingshot
    Jan 31, 2001
    1,212
    48
    UK
    +32
    Yep anywhere between the min and max is fine, you then just use the zoom to finely adjust it.
    Normally Sony refer to the screen size in width not diagonal.
    I have the PDF of the manual which has a couple of pages on positioning and how too calculate projector position. just let me have your EMail and I'll send it to you.
  6. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    Becareful with light output and zoom lenses.
    Most projectors suffer with quite dramatic light fall off at one end of the zoom or other. Usually the long throw part is the more efficient because it has to bend the light less. the contrast is also affected.
    I don't have figures for the Sony lens or know if it suffers in the way.Just a flag up the pole that I know most industrial projectors suffer big time.
