sony vpl-vw10ht Cieling mount question
Discussion in 'Projectors, Screens & Video Processors' started by Dino, Mar 21, 2001.
  1. Dino
    Dino
    Oct 9, 2000
    9
    uk
    can i get comments on your views for a ceiling mount for the sony vpl-vw10ht,
    all comments very welcome.
    regards Dino.
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,214
    +3,055
    The Sony one is crappy and wobbly. Buy one from Unicol Mounts of Oxford. Much better.....
    Gordon
    StereoStereo
    Intelligent Solutions for Intelligent Homes !
  3. Boris Blank
    Boris Blank
    Aug 7, 2000
    1,772
    Outpost 31
    +215
    Dino,
    Depends on your needs but I built my own - piece of MDF with holes through which bolts connect it to the projector (5mm bolts as I recall), 4 large coach screws from the MDF up into the ceilng jousts.
    The 5mm bolts had large washers on them to some movement of the projector left/right back/forward (i.e. the actual holes in the MDF were about and inch wide and 3 inches long, the washerd were about 2 inches wide). Up/down was simply a case of loosening one bolt and tightnening another using butterfly nuts. Total cost about £10 and very, very effective if I say so myself!
    Simple, easy and once its up you don't really see it as the projector (which hangs underneath the MDF) hides it all.
    The official mount ain't worth the money (unless you really need it).
    Paul
  4. Jinxybbc
    Jinxybbc
    Oct 31, 2000
    72
    norwich
    Unicol, Oxford is the company for you...great ceiling bracket and great service.Flexible & Easy to fit. e-mail me for any more info...regards Todd.
  5. Dino
    Dino
    Oct 9, 2000
    9
    uk
    Thankyou everyone who replied
    took your advise and ordered unicol
    should be coming tomorrow
    once again thanks
