Sony VPL-HW65ES Projector Review
Discussion in 'Projectors, Screens & Video Processors' started by Phil Hinton, May 1, 2016.
    1. Phil Hinton
      Phil Hinton
      Editor Staff Member
      Jan 18, 2001
      10,208
      3
      +8,301
    2. bandyka
      bandyka
      Oct 6, 2010
      3,212
      Sydney Australia
      +1,072
      Thanks for the review Phil. How would you rate the black levels against the 40ES? Where would you place it on a scale between the 40ES and the JVC X5000 the 40 being 1 and the JVC 10. Also how does it's motion handling compare against the JVC? Thanks
    3. DZarster
      DZarster
      May 1, 2016
      4
      Denmark
      I own this Projector and love it to bits! I am very intrested in seeing your calibrated settings so that I could try them for myself. is that possible?
    4. panman40
      panman40
      Oct 19, 2008
      16,174
      +4,983
      It's been said that the mild forced noise reduction can be overcome by switching on the input lag reducer, a few options disappear from the menus such as the Dnr settings but are there any issues for BD / 24p etc by using it ?.
      Thanks.
    5. panman40
      panman40
      Oct 19, 2008
      16,174
      +4,983
      Also Phil, do you think you might be able to pass on to Sony about the forced noise reduction ?, perhaps they would consider a fix via a F/W update, that should be pretty easy for them I think.
    6. djkutasi
      djkutasi
      Sep 24, 2015
      765
      Ireland
      +73
      The new Reality Creation works really well. Less noisy, more cleaner image which has almost a "4K feel", also blacks are slightly deeper than previous ES models (like 40, 50, 55ES).
      Thought the machine runs noisier (due to higher light output) than the previous Sony's and blacks are far from JVC's. Good full HD projector if you can afford. :)
    7. panman40
      panman40
      Oct 19, 2008
      16,174
      +4,983
      Any follow ups to the comments on this review ?.
    8. Fre.Mo
      Fre.Mo
      Jan 17, 2009
      20
      3
      This sentence about Motionflow in the review is not clear for me:
      We found that all added a soap opera effect to 24p images bar True Cinema which employs black frame insertion and a slight flicker to improve motion without any side effects of frame interpolation.
