JJService
I have a problem with my Sony VPL-HW45ES After 1 hour it turns off the signal and the screen is black with HDMI in the upper left corner, so it's still on. It flashes twice and the picture reappears after 3 seconds. If I watch Netflix it loses the signal and needs to restart Netflix. This only happens once, then the projector runs for several hours with no problem until the next time I start the projector with the same problem again.
I changed my HI end HDMI cable to an optical HDMI cable 10 meters. Later I switched to a Denon AVR-X3700H and I use an Nvidia Shield TV 4K to stream Netflix and other things. The problem is the same whether I use Nvidia or my Blu-Ray Panasonic DMP-BDT300. No problem with my TV. The projector has had the problem from new, but I thought it was some of the things I have changed that were the problem. Has anyone had the same problem and solved it?
Sorry if it is not completely linguistically correct it is written it is because I have used Google translator
