Sony VPL-HS50 ceiling bracket.
Discussion in 'Projectors, Screens & Video Processors' started by guyvert1, Jun 8, 2005.
  1. guyvert1
    guyvert1
    Jul 11, 2004
    391
    +8
    Seeing that Sony's is silly money, anyone found a cheaper option?
  2. PJTX100
    PJTX100
    Dec 21, 2004
    8,140
    +564
    You could make your own have a look at Gary Lightfoot's site for ideas.
    Alternatively, LMP mounts seem to be popular...
    http://www.lmp-pc.co.uk/
    If they are too steep, there are cheaper options on ebay... with all the usual caveats.
    ...PJ :)
  3. ninc0
    ninc0
    Dec 19, 2002
    52
    I bought a Unicol mount for around £160.00 ish. It fits perfectly and allows adjustment in many directions. Very solidly built too... :thumbsup:
  4. guyvert1
    guyvert1
    Jul 11, 2004
    391
    +8
    I personally think its a massive rip-off for these brackets, ended up paying £75+VAT for the above LMP ones, even thats alot for what it is!
  5. martian1
    martian1
    Dec 30, 2001
    2,396
    113
    Sunderland
    +638
    Have to agree got a vogels £92 still to expensive and pretty flimsy for the money. :eek:
