Sony VPL-HS20 scart RGB connection
Discussion in 'Projectors, Screens & Video Processors' started by b6b6, Jan 28, 2004.
  1. b6b6
    b6b6
    I have a DVD with Scart output and no component connection.
    Do the cables supplied support PJ-Multi to Scart?
  2. ailean
    ailean
    You get a single PJ-Multi 10m cable with composite, S-Video and component connectors on the other end. I'm not sure what the other available cables are or if direct scart RGB is posible (I'd like to know thou :) ).
