Sony VPL HS10 and/or HS2 Manual Wanted
Discussion in 'Projectors, Screens & Video Processors' started by talizker, Jan 14, 2003.
  1. talizker
    talizker
    Aug 21, 2002
    1,032
    +45
    Does anyone know if there is a downloadable manual for the HS10 and HS2 or indeed any technical info on the Sony site [can't find any info in either unit!]. I am particulaly interested in the throw/size info and the location of the bottom of the picture in relation to the pj [table mounted] Also, are there any horizontal/vertical adjustments like the Sanyo Z1.
    TZK
  2. benmc
    benmc
    Jul 2, 2002
    175
    Berkshire UK
    +7
    I have got a spreadsheet from the throw size of the HS10, I can mail it to you if you wish (1.2 Meg)
    As far as i know the HS10 will not do lens shift. It will do keystone correction though.
    Ben
  3. talizker
    talizker
    Aug 21, 2002
    1,032
    +45
    I have a rough idea of the throw for ths HS10 from projectorcentral - It is perfect for my placement options.... Was wondering if the HS2 was similar. Also wondered where the bottom of the projected image falls in relation to the unit?
    Thanks!
  4. dean randle
    dean randle
    Jan 9, 2003
    154
    UK (Bromley)
    +6
  5. talizker
    talizker
    Aug 21, 2002
    1,032
    +45
    Hi Dean
    Thanks for that, been looking for some official info for ages! It doesn't tell me everything but at least I know that the speical Sony AV Cable to get Component Input [not supplied] is only 5m long which is no use to me! It seems an extra £140ish Connection box is required:( [getting closer to the HS10 price....!]
    Thanks again!
  6. rumnblack
    rumnblack
    May 21, 2002
    35
    Sutton Coldfield, W. Mids
    The lead supplied with the HS10 is 10m long(!) and has the PJ Multi connector at the projector end, and 1 x RCA for (Composite video), 1 x S-Video and 3 x RCA (Component) on the other end.
    Before I bought the HS10 I thought I would need extra cables but hooking these up to my Denon 3801 it does everything I need.
    Hope this helps.
  7. julianf
    julianf
    Hi , i have spent many hours trying to find offical sony details on this pj and now i have full offical manual, i can mail it to you it is 3.5mb let me know.
    i orderd my hs2 last week after demo @ curry's in romford essex very impressed can't wait to get it - next week i hope.
    Julianf
  8. julianf
    julianf
  9. sonn
    sonn
    You can download the HS10 manual here
