Sony VPL-HS1 (cineza) replacement bulb
Discussion in 'Projectors, Screens & Video Processors' started by frog, May 1, 2003.
  1. frog
    frog
    May 1, 2003
    63
    Our projector badly needs a replacement bulb. We placed an order on a website approx 4 months ago with a swift delivery promise... we are still waiting :mad:.
    I have contacted local sony centres, sony broadcast, sony's suppliers, etc... and no one seems to know when the darned things will be available.
    Anyone else out there needing a bulb, have you have more luck ? Or should I treat my projector as a commodity, stick it in the bin and buy a new one...
  2. sonn
    sonn
    perhaps worth to try directly from Japan --- www.pricejapan.com, they will answer you almost immedeately by email
  3. frog
    frog
    May 1, 2003
    63
    Thanks, I will give it a try.
    Anyone got experience of dealing with them for spares ?
  4. sonn
    sonn
    I have ordered sony interface cable SIC-HS30 via them. no problems so far. PJ came almost immediately. Excellent service. Just do a search, there are lot of references to them at this forum. They are only madiators though, i. e. they have to order an item from others, and this might take time.
  5. frog
    frog
    May 1, 2003
    63
    I have just received a response from them, just need to convince wifey to part with money on its way to japan now...
    will run a search to find out more about other people's experiences.
    Thanks for the help.
