hello i have a Sony VPL-FH31 with lamp LMP-F272 i was wandering if it is possible to technically install a FH36 lamp (partnr: LMP-F331 ) inside a FH31 beamer
i have seen that the lamp chassis is different, but i think the elektronics inside is the same in both projectors. The lamp chassis is a bit different and this is done just to sell the FH36 as a more expensive model ( because of the ansi lumen). is it possible to install the bulb from a LMP-F331 in the LMP-F272 chassis? and after that inside the VPL-FH31. so i get the higher ansi lumen 3900 in eco. so even on ECO mode i have nearly normal mode compared with the Original lamp.
eco mode normal mode
Sony VPL-FH31 3400 lmn 4300 lmn
Sony VPL-FH36 3900 lmn 5200 lmn
Compare Projectors
information wanted please.
Compare Projectors
