Sony VPL-CX1 problem - please help
Discussion in 'Projectors, Screens & Video Processors' started by Blaine, Sep 23, 2003.
  1. Blaine
    Blaine
    my projector turns off after about 3 hours viewing. The fan/temp light starts flashing, and according to the instructions that means the fan is broken. I'm sure it's not, as for 3 hours it works and I can here it!!!! Could it be overheated ? The instructions says a lit up (but not flashing) fan/temp light means it is overheated. Perhaps more space is needed under the fan, (about an inch now), or could it be more serious ?
    thank you for your help
  2. JUS
    JUS
    Jan 21, 2003
    3,164
    Plute
    +213
    My Z1 cut out once. I left a safeways bag near one of the air intakes. It had sucked the bag close to the pj blocking the intake. oops.
    Not sure about your particular pj but it should have intakes on the side, front or back. Are you saying theres only an inch gap between the intakes and the box or whatever it's in? Doesn't sound like enough to me.
  3. Comer
    Comer
    Sep 21, 2001
    1,365
    Ireland
    +82
    Although Safeways bags are particularly prone to do this to projectors, watch out for some of the other supermarket bags also.
    Hope this helps
    Conor
