Sony VPL-CS2
Discussion in 'Projectors, Screens & Video Processors' started by DVDPete, Apr 8, 2001.
  1. DVDPete
    DVDPete
    Can anyone tell me please if the CS2 lcd projector from Sony is able to be ceiling mounted?
    Does it have problems with macrovision?
    Has is got true 16:9 display or does it just cope with a squeezed 16:9 image.
    I have 1800 pounds to spend so any other suggestions much appreciated.
    Pete
  2. Spacecat
    Spacecat
    Apr 1, 2001
    3,406
    London
    +1,071
    well the consensus here seems to be get a Toshiba MT1z (if you can stretch to 2K)
    or a Sanyo PLV30(also about 2k).
    personally i would put it on a small shelf
    behind my sitting position I use a TV bracket for my projector.
    i won the tosh and it is superb but take a look and make up your own mind
  3. DVDPete
    DVDPete
    thanks spacecat....
    just reading about the MT1 - could possibly stretch to 2k - any recommended suppliers ?
    Does the Sanyo have true 16:9 like the MT1z?
    cheers,
    Pete
    [ 08-04-2001: Message edited by: DVDPete ]
  4. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,516
    UK.
    +3,021
    You could try a second hand Davis DLS8 or 450 if you can find one. They produce excellent pictures when driven by a hcpc.
    Don't forget to demo before you buy though.
    Happy hunting. :)
    Gary
  5. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,516
    UK.
    +3,021
    Happy hunting. :)
    Gary
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,215
    +3,068
    Just a wee point you say that the MT1 does true 16:9. Not quite sure what you mean but it does 16:9 the same way that those DLP's and the Sanyo PLV30 do 16:9. They re-scale the incoming image and display it on a reduced amount of pixels on their 4:3 panels.
    The only fixed panel projector which uses it's full panel resolution to re-play 16:9 DVD's properly on, in this country, is currently the Sony VPL10HT. This is because it has 16:9 LCD panels inside.
    Just thought I'd clear that up.
    Gordon
  7. Guest
    In answer to the original question, the vpl-cs2 can NOT be ceiling mounted! A major mistake for SONY I think!!
    I still have to hots for the HITACHI cp-s220 myself (just to confuse you more) and I have seen it for 1550 quid +VAT
