Sony VPL CS1 Video Projector - remote needed
Discussion in 'Home Cinema Control & Remote Controls' started by Fantastic Mr. Fox, May 16, 2001.
  1. Fantastic Mr. Fox
    Fantastic Mr. Fox
    Hi - first timer here, and wondering if anyone can point me in the direction of a remote that can replicate the commands of the optional AV remote that Sony trys to flog owners of the Sony VPL CS1 LCD video projector? - Sony wants £110 for the simple remote, but I was curious to find a code or cheap way of replicating the commands.null
  2. Fantastic Mr. Fox
    Fantastic Mr. Fox
    Thanks Fartpants,
    I'll search the net a bit, any good sites to look at?
    Fantastic Mr. Fox
  3. Fartpants
    Fartpants
  4. Fartpants
    Fartpants
    Not as cheap but more flexible, get a pronto and control all your kit, if the codes are not in the built in library then they may be on the net, do some searching before you buy.
  5. Fantastic Mr. Fox
    Fantastic Mr. Fox
    Ta Fartpants - I'd already found it but nought there, the search continues....
    Fantastic Mr. Fox
