Sony vpl 11 "draper Screen"
Discussion in 'Projectors, Screens & Video Processors' started by darren7, Aug 19, 2002.
  1. darren7
    darren7
    HI people
    I am looking at the unicol mount and would like some advise, the ceiling is level with the wall the screen will go on, the screen will have to be fitted around 4-6 inches down, so what if any extension poles will I need with the Unicol mount, what are you guys using,
    Someone told me that the projector lens must be level with the top of the screen, in some demo rooms this is not always the case. What do you people think?
    Draper wall mounts, the diagram that comes with the screen is not that clear, I need the wall mounts to fix it as flush to the wall as I can, will the mounts make it real flat to wall? Where can I purchase these, as this is what I need.
    Also I need to run RGB and Component Cables, looking at 5M is there any pukka cables you can recommend for this distance.
    Prices shops Please
    Darren
