Sony VPL-10HS DVI to VGA
Discussion in 'Projectors, Screens & Video Processors' started by Lynchpin, Feb 12, 2003.
  1. Lynchpin
    Lynchpin
    I just got a VPL10HS as an upgrade from a PT100 and I want to connect my iScan V3 to it rather than using S-Video although I'm not keen at all on giving Mr Sony about £100 for a simple lead, unless there's something i don't know.
    Can anyone recommend somewhere in the UK that I can get an adaptor to fit the bill or a lead at a sensible price?
    K.
  2. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    Welcome to the forum :hiya:
    For a DVI lead check this out
    Conor
  3. Lynchpin
    Lynchpin
    Thanks for welcome Comer :)
    Yup I saw that and i've kinda sussed that there seems to be no alternative to the Sony lead which seems a tad expensive for all it is. :thumbsdow
    Nil points for Sony not including that in the box. Still I suppose I can live with S-Video for a few days until i can lay my hands on a suitable lead.
    However on reading through many of the past threads on the subject there seems to be two different ways to get a signal in from a scaler/line-doubler, either the Sony VGA breakout lead or a VGA to component lead (which i can't find!) to give component into the PJ. To be honest I'm not sure which is the best way or indeed if there is a best way to achieve it. I'm not even sure that using the iScan will make much difference really!:confused:
    ATM, the projector is fed from a Pioneer VSA-AX10 amp for all sources, DVD, TiVo, VCR, DVDR, LD and PS2 and i could up it all to component from the amp, but i can't be bothered with the hassle TBH. Then i take S-Video out, into a KAT5 module to punt the signal on CAT5 to a KAT5 reciever, S-Video from that into the iScan and (currently) up to the PTAE100 using a normal VGA cable and this works well, at least I'm happy with it.
    I know a lot of you guys use HTPCs and I'm not convinced by them at all, seen a few and none have impressed me so far any more than a decent DVD player etc. so straight DVI-D to DVI-D is out for the moment. Apart from which the projector is loud enough without introducing more background noise into the mix.
    K.
  4. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    Sorry
    I misread your origonal post, I thought u were looking for a DVI cable
    Good luck with your quest.
    BTW, many members here will agree that the best picture quality is from a PC. Perhaps the PCs u saw were not setup properly
    Conor
  5. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    You've not seen the right ones then! I've compared mine to a high end PS DVD and the difference is extremly noticable via DVI.
  6. fozziebear39
    fozziebear39
    Jan 3, 2003
    1,009
    Newton-le-Willows
    +49
    Going to order one of those cables in advance of my HS10 coming, thanks Comer. I presume you are using the 10m one. Any problems with the distance? Was going to get the 7.5m one as it warns thats the maximum length.... 10m would give me a bit of slack to move stuff around.
  7. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    I had issues with a 10m lead although others seem to have sucess, I ended up cutting corners on the cable run to use a 7.5m one. I fyou can get away with 7.5m you'll stand more chance of sucess.
  8. Comer
    Comer
    Sep 21, 2001
    1,384
    Ireland
    +85
    Hey John
    I am using a 10m cable, what kind of problems did u have?
    Conor
  9. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    "White sparklies", that is Lindy claim that they were unprojected white pixels, you could only notice it in dark scenes but it was really irritating.
    I wanted to back the cable but Lindy Tech said that it was unlikly to be faulty and that I was asking to much of it at 10m, lower the resolution they said:rolleyes:
    I bought a 7.5m drom nexnix instead and its fine so I've sent the 10m back to Lindy for a refund, have to wait and see if I get it or not though.:(
