B
blackpepe
HDTV tuner is connected with the SONY VPH 1272Q projector through COMPONENT cable, so the signal goes from HDTV tuner by the COMPONENT cable, then to AVT-3800 imageMAX PLUS Video Scaler and finally to PROJEKTORA RGB/YPBPR. When I switch to the 576p, 720p 1080i resolution on the tuner, strange things happen (blinking on the screen, double image, white stripes on the whole image, crazy !! I can't see anything!) When I switch to 576i resolution everything is ok. Could anybody help me with that? What can I do so I could watch the movies in HD?
The projector's max highest resolution is 1600X1200, so I don't get it!
Im from Poland
Im from Poland
