Sony vph 1251 ac power?
Status
Not open for further replies.
H
hasse.r
:confused: Hi does the sony vph1251 have the same power input around the world? Is it only to change the fuse? Thanks Hasse
Roland @ B4
I've never done it but I thought it was a fuse change. The brochures indicate different models for 120v and 240v so I may be wrong.
RAMiAM
I had a Sony D50 and it was a simple matter of changing the glass fuse located next to the power inlet.
I have just checked again my 1292 it appears the same.
Projector specs in the US (www.projectorspecs.com) use to list the power specs for each projector and whether it was a pure fuse change etc.
RAMiAM
Sorry I was being lazy :)
They have changed their url from projectorspecs to crtcinema.
Here is the link for sony projectors http://www.crtcinema.com/sonyspecs.html
It clearly states that all 12xx models require a simple fuse change.
This source is pretty reliable.
I've bought numerous products from them and eMailed them regarding the voltage on my old Sony D50.
RAM
H
hasse.r
Well can you see what it says in the stamp on the side of the power box?Next to the HV block
Thanks Hasse
Status
