sony vph 1031qm
Discussion in 'Projectors, Screens & Video Processors' started by monty, Dec 29, 2002.
Thread Status:
Not open for further replies.
  1. monty
    monty
    Does anyone own one of these projectors, i've just rescued it from being skipped, can any one give any info on such a cute little machine, switched it on and it look's like everythings working, will these machine's do widescreen once setup ???
    Any help would be great,
    thanx,
    m0nty.
  2. witters
    witters
    Jul 13, 2000
    12,651
    Yorkshire
    +293
    Monty,
    I had one of these and it doesn't have anamorphic widescreen. You would need to set your source to 4:3 and put up with lesser quality I'm afraid.
    On the plus side it's a doddle to set up and great value when it's free!!
  3. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    Monty,
    If you go over to the avsforums (crt forum) you'll find out a lot about this projector (there is even a FAQ/ set up guide as well).
    Basically it's a great little projector that you can adjust to do 16:9 (you can also use a htpc to change aspect ratio) AND it will accept a progressive signal from a dvd player.
    Brian.
  4. monty
    monty
    Just like to say thanx for the info !!!!
Thread Status:
