Sony VPH 1031 Problem with DVD pictures
Discussion in 'Projectors, Screens & Video Processors' started by Nigel Ince, Sep 17, 2001.
  1. Nigel Ince
    Nigel Ince
    Hi, i have a new (trust me) Sony VPH 1031q CRT projector, i know its an older model, but when i put DVD pictures through it the screen goes haywire & it wont play it properly. I think macrovision has something to do with it, as Sky & other things play fine through the RGB scart.
    It doenst do it on all DVD's mainly R1 (but Fargo R1 works fine) & most R2 dvds are ok, but Hannibal weoldnt play.
    Im sure macrovision is to blame, if so any ideas as i dont really want to get rid on my Sony 735 DVD player
  2. Gordon @ Convergent AV
    Jul 13, 2000
    14,177
    +3,004
    Does your Sony have RGB output capability. If so you may want to try a RGB to VGA(RGBHV) adaptor from John Sim, <a href="http://www.rgbtosvideo.co.uk" target="_blank">www.rgbtosvideo.co.uk</a>
    This will strip out Macrovision I'd have thought.
    Gordon
  3. Nigel Ince
    Nigel Ince
    Hi Gordon, thanks for the help, i dont know what you mean 'has your Sony got RGB output' do you mean input, it has a scart socket on the front marked RGB1 there is a com port type computer connector next to it labeled RGB2 there is no support for S-Video on my projector that i can find - is this what you meant
    Cheers for the reply
  4. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I agree it's a macro vision problem.<br />Macro vison breaks up the sync signal to prevent you linking recorders. However some of the sensitve projectors had the same problem.
    It would be worth giving MarataVision a call, They were the distributors of sony CRT's.
    <a href="http://marata.co.uk" target="_blank">Maratavision</a>
    Tel 020 8348 1496
    They may know of a quick fix
    On a barco it is just a couple of components
  5. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    or you could just get a copy enhancer from te likes of lectropacks <a href="http://www.lektropacks.co.uk/" target="_blank">http://www.lektropacks.co.uk/</a>
  6. Nigel Ince
    Nigel Ince
    Hi matey, cheers for that, they dont know about the 1031, they never had anything to do with them.
    any ideas where next ?
  7. Nigel Ince
    Nigel Ince
    Hi all, still having problems here with this unit. All R2's work fine & fargo & dirty dancing, father ted R1's all work fine, but *no* other R1's will work, i just get screen break up image jitter all over the place & sometimes a rolling picture & sometimes nothing at all.
    Has anyone got any ideas at all - i even rang Sony Pro install & they didnt have a clue.
    I was wondering where the vertical hold pot was as this could be the problem ????
    My friend had one of these too & he had the same problem until he got a pioneer DVD player & it had macrovision removed.
    Anyone want to swap a decent pioneer for a brand new Sony 735 in silver
    Nige
  8. GagHalfrunt
    GagHalfrunt
    Sep 1, 2001
    527
    North Cotswolds
    +3
    Why not pay someone like Techtronics to remove Macrovision for you instead of changing your player?
