Sony VHP-722QM any good ?
Discussion in 'Projectors, Screens & Video Processors' started by daveha, Jul 19, 2005.
  1. daveha
    daveha
    Jan 16, 2002
    59
    Hereford
    Hi all,
    I've just rescued one of these Sony VPH722, CRT projectors from work. Usual story, its been replaced with a little desk model with a nice picture, but sounds like a hover craft ! Is this model any good ? it has a remote control unit and about 30 foot of cable. The picture is 4:3, all the colours are there and about the same brightness. It's got an instruction manual for operation, and for dealer setup (so many adjusters !). I have just got a second hand Z2 :) so I don't realy need a CRT projector as well, is it the sort of thing I could sell on, or should I wheel it, case and all, to the nearest skip ? Any comments greatfully received.
    Dave
  2. Stuart Gray
    Stuart Gray
    Oct 7, 2002
    78
    Christchurch, Dorset
    +7
    Hi Dave. I've got one of those hanging in my cinema, I bought mine secondhand. I've had it for about four years. I think they're quite old, dating from the eighties. Mine used to display a digital clock, visible only on large white areas. It gives me a five foot wide image, so I'm quite happy. It'll do till I can get hold of something better, though I'm inclined to replace my receiver (Sherwood R925) next, when funds allow.I installed the Sony myself, after obtaining a technical manual and a ceiling bracket. Cheers!
