Sony Vegas - please help!
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by linso1000, Feb 10, 2009.
  1. linso1000
    linso1000
    Feb 10, 2009
    Hi I have Vegas Movie Studio Platinum from which I have to pull edited clips of a tv show for a website.
    This has all been going well, but the last 2 batches of discs have not loaded, they don't build as I import them. Then when I put them in the video, either they are out of sync, or I only get a few seconds of video with non-compatible sound.
    Two things strike me:
    I get an error message when I load up Vegas saying "Failed to register with windows terminal services"
    and
    The discs appear to be read only.
    Do you think it's either of these things or do you think it's something else - have you ever had this ? could it be the type of discs being used ? The production manager says he isn't doing anything different on transfer to disc, so I'm loathe to keep asking him for new discs if it's something else.
    Anyone got any suggestions - and how do I fix the above error message ?
    Lins
  2. glesgaguyav
    glesgaguyav
    Jul 30, 2006
    1,143
    63
    Glasgow,Scotland
    +117
    Wouldn't you be better ripping the disks to your HDD and edit them from there?
