Sony Vegas is just showing Audio tracks and not the actual video, any ideas ?
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by davebrown88, Feb 7, 2009.
  1. davebrown88
    davebrown88
    Sep 23, 2008
    134
    +5
    Hi Sony has been working fine and I am not to sure if I have accidentally pressed a wrong button but when I open a video it shows it as a audio track in the time line with no actual video.
    Pressing space/play just plays audio in the preview window and not video. been messing around with it for 2 hours and just cant seem to get my videos to play so I can edit them.
    Thanks for any help!! :thumbsup:
  2. alpine101
    alpine101
    Jul 1, 2006
    1,152
    63
    +109
    Are you sure you put it into the video track? I seem to remember it will happily paste them into the audio on the basis you just wanted the sound!
  3. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    Is it a mpeg2 file?
    If so, ( and it worked fine before) , why not try another format of video file as a test
  4. ddvmor
    ddvmor
    May 2, 2007
    89
    11
    Bristol, UK
    +3
    I had a problem with this a while back and, although I didn't entirely resolve it, it seemed to be related to dodgy video codecs - if you're using footage downloaded from the net or perhaps from a mobile phone, you may come across this - if it's straight off your camcorder, then I've no suggestions!
    As I recall, I managed to rescue some of my footage by converting it to a different format (mpeg4 to avi, I think) using a conversion program downloaded off the net - I don't still have it as the trial period ran out and sadly don't recall what it was called. there's plenty of 'em out there, though!
  5. evilgenius
    evilgenius
    Apr 27, 2007
    1,603
    48
    Derry
    +92
    if he used a dodgy video codec, then surely installing FFD would resolve the problem as it supports the most codecs including exotic ones, then vegas would pick up on this.
  6. senu
    senu
    Aug 26, 2005
    19,349
    Denham, South Bucks
    +2,811
    Not all though
    sometimes installing divx helps, as well if it is an mpeg4 video
