Sony Vaio
Discussion in 'Desktop & Laptop Computers Forum' started by dubledene, Jun 30, 2005.
  1. dubledene
    dubledene
    got a friend selling a sony vaio for £200 model is PCG-FX205K is this any good also where can i get a charger??
  2. dubledene
    dubledene
    ok got a charger the pc has windows 2000( booooooo ) can i put my windows xp on??
  3. dubledene
    dubledene
    ahhhh c mon lads!
  4. shezzy2k
    shezzy2k
    Aug 17, 2004
    492
    28
    +26
    There's no reason why you wouldn't be able to put XP on your laptop as long as you have up-to-date drivers for it. I would also check the amount of RAM as I believe that yours comes with 128MB as standard. The max amount for your particular laptop is 512MB and I would certainly consider more than 256MB to make XP run smoothly based on my own experiences.
    Look for driver updates HERE
    and RAM upgrades HERE
    Hope this helps!
