Sony VA-555ES And Bose Acoutimass 15mk2 Speaker/crossover settings?
Discussion in 'Home Cinema Speakers' started by SCARFACE, Apr 16, 2003.
  1. SCARFACE
    SCARFACE
    Hi there,
    Have the above setup and am having difficulty deciding the correct settings for the following,
    Amp:
    Speaker size : at the moment set at large
    Speaker level: at the moment Front/center/rear all set
    at the factory setting(equal)
    Speaker distance: at the moment set at measured distance between myself and speakers/sub,
    Fronts: 8 Feet
    Center: 8 Feet
    Rears: 3 Feet
    Sub: 8 Feet
    Should these be set to measured distance or further / closer
    away.
    LFE cutoff : at moment set at standard 120HZ
    LFE mix level : can someone please explain this to me as the manual is a lttle bit vague as well as the best setting, at moment set at 0dB
    Bose Acoustimass Module/Sub:
    LFE Setting : at the moment I have the dail turned completely clockwise(max)
    Bass Level: at the moment have dial set in the middle.
    Any help and tips with above would be appreciated.
    Regards
    Tony
