Sony va 555es 5.1ex mode firmware 1.74
Discussion in 'AV Receivers & Amplifiers' started by I am maximus, Jan 27, 2003.
Tags:
  1. I am maximus
    I am maximus
    Nov 14, 2000
    76
    Surrey,UK
    Hi all
    My amp is back from Sony with the upgrade done which works,my question is on Star Wars AOTC I have set the soundfield to auto decode but cannot get the centre channel to register on the amp unless its set to 6.1 to on not auto please could someone advise .Many thanks in advance
    (I am talking about 5.1ex of course)
  2. Johndm
    Johndm
    Jan 25, 2003
    1,829
    Bedford UK
    +66
    I believe the upgrade only fixes DTS ES 6.1 decoding in AFD mode.
    I've read somewhere that DDEX still has to be manually switched.
    hope this helps
  3. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    Star Wars ATOC hasn't got the flag to make the AV reciever automatically switch to 6.1 mode, so you have to do it manually. There is no way the AV reciever can tell that is is DDEX. There are only a few titles that do have the flag, including Jurassic Park III and Disney's Atlantis, they stopped using it because it caused "drop outs" with some AV recievers. All DTS ES titles are flagged so the AV reciever can switch to the right mode without user intervention.
  4. I am maximus
    I am maximus
    Nov 14, 2000
    76
    Surrey,UK
    Many thyanks guys for the info,I,ll TRY jURASSIC PARK TODAY
  5. EvilMudge
    EvilMudge
    Just thought I'd add that Gladiator DTS:ES is unflagged - would be important to someone who calls themselves Maximus. :cool:
  6. stranger
    stranger
    is it imperative to have the firmware upgrade? I leave my amp in 6.1 for dvd and have not had any problems.
  7. cybersoga
    cybersoga
    Apr 7, 2002
    1,630
    48
    UK
    +25
    EvilMudge, what version of Gladiator have you got? according to Rewind DVD region comparisons only the region 1 version has DTS ES Discrete, but region 2 should have DTS ES Matrixed, but my R2 copy shows no signs that it should be in DTS ES - it's not marked on the case, disc or on screen menus as DTS ES, and it isn't flagged as DTS ES.
  8. EvilMudge
    EvilMudge
    R2 Gladiator is DTS:ES but unflagged, it's about the only exception that I can remember to the rule that EX is unflagged and ES is flagged.
    R1 is discrete ES IIRC - any decoder that recognises extension data should switch to 6/7 speaker mode.
