sony V with mac and ps3
Discussion in 'Sony TVs Forum' started by acollins, Oct 20, 2005.
  1. acollins
    acollins
    Feb 21, 2002
    132
    16
    Portsmouth
    how would i be able to connect a Mac Mini and an PS3 to the Sony V series LCD, I believe the only input they can use is the HDMI of which the Sony only has 1.
  2. andrewfee
    andrewfee
    Apr 27, 2004
    3,066
    +500
    Unfortunately, the Sony V isn't designed with PC/Mac connectivity in mind, as it has no VGA input and the HDMI socket has overscan.
    As for PS3; HDMI.
  3. acollins
    acollins
    Feb 21, 2002
    132
    16
    Portsmouth
    should i be looking for an lcd which has a VGA and HDMI if i want to connect a Mac and a PS3?
  4. xprezz
    xprezz
    connect your PS3 with component, I am sure it will have component output. Or better yet get an Xbox360 :p
  5. acollins
    acollins
    Feb 21, 2002
    132
    16
    Portsmouth
    thanks for you replies, I am still a bit unsure as to what connections I will need
    It is difficult to choose an LCD(or even a Plasma) if you dont know what connectors the source will have, I am talking SkyHD, PS3, Xbox360. none of which are out yet. (no doubt i will get at least of the above.)
    I currently have Sky+, PS2, DVD(with component), gamecube, (will also need to be able to connect video), soon be getting a macmini for internet, photos, itunes etc).
    I seem to choose a screen, then find something on it i'm not sure about and change my mind, don't know if i will ever get one at this rate.
  6. xprezz
    xprezz
    this will be a problem with most of the screens that are out at the moment. I plan to solve it with a receiver that handles both component and HDMI. They are slowly starting to hit the market and JVC and Philips have some that arent too expensive either.
  7. gateway2k
    gateway2k
    Nov 20, 2004
    38
    11
    A mac Mini will connect to the V series using a DVI to HDMI cable, see V series thread.
    G
